Renault 11 TXE on-board computer faults
tanago
Messagepar tanago » 17 févr. 2020, 21:09
Hi all,
The On-Board Computer on my Renault 11 TXE shows random static numbers. Currently it just shows "506" and doesnt change when I press any button! What can be wrong and can it be saved?
Thanks in advance!
Re: Renault 11 TXE on-board computer faults
Messagepar coptere » 09 avr. 2020, 00:57
Hi,
Is there any pictogram on your screen ? Such as Fuel tank, temperature unit, speed unit ?
Have you tried to disconnect the car battery (-) and put it back on again ?
You may find some directions here although it's in french, should you need any help please ask if you need translation :
https://www.renault-9-11.fr/images/Docu ... DEBORD.pdf
tanago
Messagepar tanago » 30 août 2020, 19:07
coptere a écrit :Hi,
Hi I managed to fix it, now it works but very limited
Outside temp - 50°
Fuel - 76L?? :zinzin:
Fuel consumption - missing
any ideas? :voyons:
tanago
Messagepar tanago » 02 sept. 2020, 19:14
I did some measurements with the multimeter and compared them to the ODB manual
tanago a écrit :Outside temp - 50°
showed about 150ohms which is outside the usual range so I ordered a new sensor
tanago a écrit :Fuel - 76L?? :zinzin:
the 1 & 4 connectors showed 241 ohms which is the max, maybe the fuel float is broken but connectors 1&3 that connect to the dashboard show the correct fuel level
anyone knows if the dashboard & odb have 2 different floats?
tanago a écrit :Fuel consumption - missing
the speedometer is disconnected from fuel flow meter, can that affect the fuel flow meter? or the fuel flow meter just faulty?
