My Renault 11 Turbo ZENDER
Alexventura
Re: My Renault 11 Turbo ZENDER
Very nice R11 Turbo ZENDER
Very well work on the engine bay :bien:
What is the tire size?? Does it 195/50/15?? On the picture they look bigger...
it is 195/60 now ,for a while :nul:
Euh my english is so bad, now I write in french, sorry but someone translate isn't it alex? or jlez? :bleble:
Pourquoi une monte de pneus si haute? les routes de lituanie sont mauvaise?
I got a transelator.
Well , roads are really bad :polol: but there is no "drop" becouse firstly I want to finish with engine bay, than I go to suspension :bien: it is in my future plans :bien:
ah ok; you have a translator!! it's a good idea to do the engine in first ;)
Alexventura
be carreful with this size of tire your velocity indicator is wrong now.
Hi! Yesterday I went for a ride with my car.
Suddenly , when I get full boost one of the hoses from turbo to IC "jumped" out (dont know if you understand what I mean ) , I stopped and fixed it and after that the turbo stopped boosting it is not going over 0.5 bar ( it should go to ~1.2) and it is getting rpm's very hard... Also when on idle and pulled up to about 3.5 k rpm stock boost gauge is getting mad... It never happened before...all vacuum hoses are new- silicone , I dont know from where to start searching problem.
And one more problem... 2 weaks ago I first time tried to go for a maximum rpm on 2nd gear , and guess what? It is not going over 6k rpm... Why is that so? I thought there is no some kind of rev limiters on carb , am I wrong?
well I hope you understand what I wrote.. thanks for any advices...
sorry for my English...
petite traduction dans les grandes lignes pour que les seniors nous aident aussi :
Quand il était en pleine charge, une des durites du turbo à l'échangeur s'est barré.
il s'arrete, la remet, mais apres ca, pas plus de 0.5 bar......au lieu de 1.2
puis si je crois avoir compris, du ralenti il accelere a 3500 et la jauge de TuRbo s'emballe.
toutes ses durites sont neuves en silicone.
Un autre pb, il a poussé sa seconde a fond, et ca n'a pas dépassé 6000trs, pourtant il n'y a pas de limiteur ?
thanx for translating! :bien:
L'échanger a cédé sous la pression :bah:
Alexventura
Pour le turbo moi aussi au début ça soufflet pas j'ai juste resserrer la durite qui sort du turbo vers l'échangeur et ça a beaucoup plus soufflet.
Et pour la seconde à fond je suis pas sur que le cléon est capable d'accepter beaucoup plus que 6000 tr avec son arbre à came latérale et ses tiges de culbuteur.... après je sais pas....
could anyone translate , beceuse my translator not working :bah:
Alexventura a écrit :Pour le turbo moi aussi au début ça soufflet pas j'ai juste resserrer la durite qui sort du turbo vers l'échangeur et ça a beaucoup plus soufflet.
For the turbo I too at the beginning that bellows not just have to tighten the radiator hose which goes out of the turbo towards the heat exchanger(interchange) and that has much more bellows.
And for second profoundly I am not on that the cléon is capable of accepting much more than 6000 tr with its tree with cam lateral and its pushrods later I know not....
voilà :wink:
EDIT :
Henry c'est pas bien les traducteurs informatiques..... :bleble:
donc
For the turbo problem I had it too, but I just tightened the hose more (from turbo to IC) and that it get better.
For the 2nd gear problem, I am not sure that the Cleon can accept 6000rpm
well thanks for advices, tomorrow going back to garage... I will let you know if I found anything.. :bien:
Utilisateurs parcourant ce forum : Aucun utilisateur enregistré et 29 invités
