Restauration débitmètre (tentative de refonctionnement)
julien35
Re: Restauration débitmètre (tentative de refonctionnement)
Messagepar julien35 » 16 mars 2021, 12:37
Non , pas essayé, démonté depuis le passage en injection, je ne pense pas que soit compatible
julien35
Messagepar julien35 » 16 mars 2021, 12:42
freds a écrit :Pour Julien, puisque tu es passé en injection, as-tu regardé si le calculateur sort une info débitmètre ?
https://www.forum-super5.fr/index.php?/ ... pour-lodb/
Il faut que j'étudie ça, merci pour le lien
tanago
Messagepar tanago » 02 juil. 2021, 10:26
I tried fixing 2 debitmetres without any success (btw best cleaner for them is acetic acid/vinegar concentrate).
Finally found this site that offers them new but I took the last one: https://www.all4renault.com/products/77 ... -gasolina/
(369.33 Kio) Téléchargé 2458 fois
Messagepar coptere » 03 juil. 2021, 09:57
Nice, I must have been very expensive though ! Hope it works properly.
vm57
Messagepar vm57 » 10 oct. 2021, 18:08
Tanago, does this new debitmetre works properly now ?
I tried with Zebulon's utltasonic bath on two debimeters, no result, it don't work better. I don't find yet a solution to help it to restart.
I hesitate to destroy one to try understand where the problem comes from.
tanago
Messagepar tanago » 10 oct. 2021, 21:43
I haven't installed it yet!
Currently I'm assembling the engine, hoping to finish it in a few days.
Then I have to fix a leaking fuel line and install the new debitmeter and hope it works :yes:
I'm really interested why originally they place the fuel filter on the back of the engine. This way I see 2 problems:
1. filter cleans the fuel AFTER the debitmeter
2. filter lowers the fuel pressure AFTER the fuel pressure regulator inside the debitmeter.
I think I will place the fuel filter just after the fuel reservoir.
Fichiers joints
(40.39 Kio) Téléchargé 2320 fois
vm57
Messagepar vm57 » 12 oct. 2021, 21:34
On my Turbo the previous owner had done it exactly like that, a filter just before the electric pump. I think it's very good and left it in place. There is also a large filter right after the pump, so with that it gets dirty less.
(150.08 Kio) Téléchargé 2319 fois
These filters were in place but the debitmeter still no longer works
Utilisateurs parcourant ce forum : Aucun utilisateur enregistré et 7 invités
