Restauration débitmètre (tentative de refonctionnement)
Re: Restauration débitmètre (tentative de refonctionnement)
Non , pas essayé, démonté depuis le passage en injection, je ne pense pas que soit compatible
freds a écrit :Pour Julien, puisque tu es passé en injection, as-tu regardé si le calculateur sort une info débitmètre ?
https://www.forum-super5.fr/index.php?/ ... pour-lodb/
Il faut que j'étudie ça, merci pour le lien
I tried fixing 2 debitmetres without any success (btw best cleaner for them is acetic acid/vinegar concentrate).
Finally found this site that offers them new but I took the last one: https://www.all4renault.com/products/77 ... -gasolina/
Nice, I must have been very expensive though ! Hope it works properly.
Tanago, does this new debitmetre works properly now ?
I tried with Zebulon's utltasonic bath on two debimeters, no result, it don't work better. I don't find yet a solution to help it to restart.
I hesitate to destroy one to try understand where the problem comes from.
I haven't installed it yet!
Currently I'm assembling the engine, hoping to finish it in a few days.
Then I have to fix a leaking fuel line and install the new debitmeter and hope it works :yes:
I'm really interested why originally they place the fuel filter on the back of the engine. This way I see 2 problems:
1. filter cleans the fuel AFTER the debitmeter
2. filter lowers the fuel pressure AFTER the fuel pressure regulator inside the debitmeter.
I think I will place the fuel filter just after the fuel reservoir.
- Fichiers joints
- (40.39 Kio) Téléchargé 2291 fois
On my Turbo the previous owner had done it exactly like that, a filter just before the electric pump. I think it's very good and left it in place. There is also a large filter right after the pump, so with that it gets dirty less.
These filters were in place but the debitmeter still no longer works
Retourner vers « Restauration »
